88LX - Carb To Fuel-Injected?
  • #31
    They say it helps the 'rings to seat'....I don't really know any more about it.
    '92 Geo Metro XFi
    '87 Suzuki Samurai
    '85 F150, modded 300cid
    • #32
      http://www.hastingsmfg.com/ServiceTi...efinishing.htm
      I read the hyperlinked article. Very interesting. Didn't know they did this. 2 questions to you guys out there....
      1) How common is this on engine rebuilds?
      2) If they do this routinely on engine rebuilds, why don't they do this on cylinders right out of the factory? Or do they?
      88L - 'Twistiva' - 'The Fusion of Man and Machine'
      88LX - 'Laztiza' - Future Resurrection Project
      91L - 'Mistiva' - My Daughter's DD
      93L - 'Vextiva' - Airport Car
      • #33
        Originally posted by Twistiva View Post
        OK, interesting. Anybody else got any idea as to why it's a smart thing to have a "cross/hatch" pattern on a cylinder wall?
        As far as I know it is to help retain oil on the cylinder walls for lubrication
        1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
        Rocketchips!
        Bolt-on Weber Carb Adapters!
        • #34
          correct retain oil on the cylinder walls for lubrication They say it helps the 'rings to seat'.... and keeps compression up which equals a happy healthy engine with max power
          • #35
            Yes, this is always done on any engine. New or rebuilt. If it isn't done oil wont evenly coat the cylinder walls ( like said before ) and the rings need something to "bite into". If the bore was smooth or a mirror finish then the oil wouldn't evenly coat the cylinder and the pistons could seize in the bore. As well as the rings wont properly ride against the smooth surface and not "grab" it and seal properly.
            • #36
              I would use one those bottle brush style cylinder hones to break the glaze, and leave a cross hatch pattern on the cylinder walls.
              The person building my motor is very good. He's built high hp Mustangs in the past, so I have confidence in his work.
              I assure you he's in North Carolina not Indiana. He and another friend are working on some R&D stuff on both my motors.
              No DAE parts in this gas mileage build.
              Jerry
              Team Lightning
              Owner of Team Lightning
              93 L Lightning. BP
              • #37
                Just a little side "Blip" here that goes along with pistons,sealing and lubrication. On two stroke nitro-methane engines.There are no rings,cross hatching or oil in the crankcase. But they can survive 30,000 rpm all day long.They solely rely on the piston sleeve taper or "Pinch" @ TDC for sealing.And a mixture of synthetic/caster oil in the fuel for proper lubrication. So you can totally see how important cross hatching is in a four stroke. And why correct fuel metering is vital to any engine's longevity(on a two or four stroke). Overly rich mixture wash's away the oil on the cylinder walls in a four stroke.Overly lean in a two stroke will result in scoring and premature wear on ALL internal moving parts (not just cylinder walls).
                If you were required to prioritize the benefits of cross hatching a four stroke. "Oil Retention" would be first followed by ring sealing IMO. Interesting how this thread started out from a question concerning fuel control via carb/efi.
