I am in need of a large nose crank pulley. I want a harmonic balancer but without the secondary pulley for accessories. I am only running the alternator and water pump. I was originally looking into the SuperMiata one but I don't need the extra pulley. Does anyone know if one is available? I would prefer to stay with v groove put if one is actually available in only 4 rib I would be just as happy. lol
Crank pulley
4-rib is superior. Buy one for a 2001 Kia Rio, it's cast iron with a harmonic balancer and two 4-rib pulleys. Machine the outside pulley off. Theyre inexpensive an available brand new. PM me if you need the machine work doneLast edited by Rocketman; 03-16-2014, 11:58 AM.1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
Well on those cars listed, they would have the proper alt pulley. With a socket and some time you can put a rib pulley on a previously v setup.-Greg
Redneck Engineer
FOTY - '09
