Weber REMAN 32/36 on Allstate Carburetor website $175
  • Weber REMAN 32/36 on Allstate Carburetor website $175
    Todd
    1988 Ford Festiva L w/5 speed & Weber 32/36 upgrade
    1998 Isuzu Trooper 4X4
    2005 Ford F-150 XLT Super Cab
    1980 Kawasaki KZ1000 - B4 LTD w/Mikuni VM29s, Dyna S Ignition, Kerker 4-Into-1 Header & Vetter Fairing & Trunk
    1981 Kawasaki KZ1000 - M CSR Stock w/Vetter Fairing
    1981 Yamaha XJ550 - H Maxim
    And a brand spanking new one is $200...
    91GL BP/F3A with boost
      so, i have an 89' carbd. i could buy the one off this link, get an adapter plate and egr block off plate and be golden?
        You will have to re-jet and/or tune. Rocketman makes a nice adapter.
          that i could have a shop do. thanks, appreciate the link.
            you could probably use a universal air cleaner for this right?
              you can buy the air filter off of ebay just search Weber 32/36
                Yes, that's the one that comes with the all-in-one eBay kits. Though I don't like how it only draws in warm air in the middle of the engine bay.. going to try and convert the old air filter assembly to the Weber so I can have a cold air intake without adding extra cost.
                White '92 GL 5-speed BP, G series, Aspire/Rio swapped, "Nancy"
                1988 LX 5-speed
                ​​​1993 L 5-speed B8, E series, Aspire/Rio swapped
                Gone:
                  well i have 3' of 3" flexible conduit hooked up to an lb that has a mesh filter in it. it will be set up behind the bumper and slightly pointed down so that the air will be drawn up into it and the exit of the conduit will be right by the filter. its what i had in my honda when i had the cai on it.
