Is there anyway to get poly style stock festiva trans mounts? I have a welder so I could weld the angle iron for the rear mount and for the front mount but wanting to know if there is any stiffer way than just going with stock festiva mounts other than going crazy on the crossmember mods. Thanks
Custom BP/G series Mounts
3m window weld? That stiffens up stock mounts ALOT lol..2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
Make your own mount frames to hold standard urethane bushings?1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
Hey rocket if I do it this way Would it be harder to center the engine? And are these the type of mounts/bushing your talking bout?Originally posted by Rocketman View PostMake your own mount frames to hold standard urethane bushings?
thanks
Here's Shorestiva's mounts he's using standard inserts it looks like. Should have significantly less give than any OE mount, and you can probably shop for a harder bushing tooOriginally posted by bondo View Post
If you measure properly or start with one stock mount and then replace it after the others are made, there's no reason it should be hard to center the engineLast edited by Rocketman; 03-28-2014, 07:01 PM.1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
