Is it possible to install the roller-rocker Aspire cam in a Festy B3 carby head, using the Aspire rocker arms? I'm thinking about how I can re-purpose my Dickmeyer MPG cam. Thinking about a carby car with Weber carb, jetted as lean as possible (90 primary main), and with Matt's MPG cam making it pull in less fuel/air. Trying for even better fuel mileage.
If the Aspire cam does not have the necessary bump for the carby fuel pump, I would just use an electric carby fuel pump.
Edit: the Festy carby intake manifold does not fit on EFI Festy or Aspire heads, correct?
