i don't remember this being brought up and couldn't find it in search. do you need to use a 1.8L intermediate shaft if you're going to install a 1.8BP & G trans into a festiva? i'm thinking the capri shaft might not work since the block is a little longer. this Sephia 1.8 shaft is available from 4G for the US 98-2000 model with 1.8. comparing this pic with a capri shaft, the Sephia shaft has the bearing more towards the center of the bracket than the capri shaft.
