Originally posted by bhearts
Obx fmu
He said he didn't want to sell the adapter alone. I asked when he was active here.
But http://www.ebay.com/itm/Fuel-Rail-Ad...dc279b&vxp=mtrAny difference that makes no difference is no difference.
Originally posted by sketchman View PostPretty sure I measured that hole the stock FPR sits in, and you can tap it with a NPT tap. Not sure on the size. 1/4" maybe. Then you can just screw in a NPT to barb adapter and hook an adjustable FPR up with hose.
NPT = National Pipe Thread. So it's a threaded connector sized to fit a 1/4" pipe's inner diameter. Mic the inside of the fitting, and you'll see. It's something close to 1/4"Last edited by sketchman; 07-21-2014, 06:58 AM.Any difference that makes no difference is no difference.
I have that FPR from Matt and it is a quality piece. Here are the pics I took of it after I got it and installed it. http://imgur.com/a/eFIqP
Originally posted by gergorian View PostI have that FPR from Matt and it is a quality piece. Here are the pics I took of it after I got it and installed it. http://imgur.com/a/eFIqP
Yes. A friend of mine knows a guy that works at a powder coat place and he did the intake and valve cover for $40 .
*edit* I should specify that the red is PC but the gold is paint that I put over it. The paint probably won't last long but that's OK.Last edited by gergorian; 07-22-2014, 11:25 AM.
Originally posted by gergorian View PostYes. A friend of mine knows a guy that works at a powder coat place and he did the intake and valve cover for $40 .
