Ok just did this swap and noticed two things happening.
1st- while sitting at idle from time to time the idle will drop quite a bit and stay there for 3-5 sec. Then return to normal, and when I give it gas for a second it seems to hang up at the new rpm and comes back to idle slower then usual. The one thingI ddidn't do yet was hook up the sensor in the exgaust manifold as I need a new one. Would not having this sensor connected be causing said issues? If not any ideas?
2nd- when I turn off the engine there is a hiss that lasts for around 10-15 seconds in the fuel cannister (ish) area (havnt been able to fully pin point it yet)... any ideas what could be doing this?
