Let me get started by saying I have used the search... extensively
now that thats out of the way, about three months ago I caught the festiva bug, I bought a 92 with 349k on the clock and 20k-ish on the engine... I'm used to building n/a jeeps.... my festiva is stock and I want to install a turbo next month.
well now I run into an issue, from reading on here there is all kinds of contradictions on what needs to be done, upgrading injectors or not, New fuel pump or not, all types of information with none being of much use...
the plan is to delete the muffler, install a rear mounted turbo, pipe the air back to the air flow meter.
delete the bottom portion of the air box and build a flange for the air flow meter, at 6-8 psi on a small turbo like one off a 89-94 eclipse, would any fuel delivery upgrades need to be done?
There will be no intercooler, I don't want the turbo near the engine bay in order to cut down heat and save space.
Plus, why have people be able to see it when you can surprise them on the road?
If you are going to use any abbreviations, please define them... im New to the festiva world...
engine swap is not an option at this time, im doing a diesel swap in a 89 jeep Comanche and dont need two engines in the shop this fall.
thank you all ahead of time for any advice or input you can give
