Sorry if its been covered but I couldn't find any badh2. Im a mad keen 4x4 person but got a 1996 festy 1.5L for work. I keep blowing diff center 3 one now looking for a 4th one. Its the shaft for the spider gears that keeps letting go sending spider gears out the side of the box and even had one in my bell housing lol. Is there a stonger center I can put in
diff eater
Welcome to the site. Since you have a 96 Festy with a 1.5 you must be in either NZ, AU or ?
A little more info would help, type transmission fluid you use in it, turbo motor? How do you drive it? Wide open with power shifts? Several things can cause that to happen and a most involve excessive power on a stock transmission.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
Hard launches typically do that to the stock diff's lol
Its a Australia we have the 1.3L and 2 different 1.5L. Its stock but yes I do drive it hard lots of limiter ( I think thats why lol) iv forget what motor in mine but iv had both Mazda and kia 5 speed boxes in it. I want stronger becouse I want to turbo it becouse they are very rare to see one here that flys as they are more of a granny spec car
Stop wheel hopping and that should help keep the diffs in one place. The case can't take the torque that's caused by the wheel suddenly getting traction. It causes the case to flex and letting that shaft move out of where it should be: then the transmission explodes because things bind up. Smooth tire spin that transitions into traction without wheel hop will not cause an issue.The Festiva Store
Sounds like you just need to tighten the nut behind the wheel!Originally posted by diff eater View PostIts a Australia we have the 1.3L and 2 different 1.5L. Its stock but yes I do drive it hard lots of limiter ( I think thats why lol) iv forget what motor in mine but iv had both Mazda and kia 5 speed boxes in it. I want stronger becouse I want to turbo it becouse they are very rare to see one here that flys as they are more of a granny spec car1988 Chevy Sprint Turbo 997cc
Perhaps new struts are in order as well to help keep hop to a minimum.Ian
Lmao!!!Originally posted by Aaronbrook37 View PostSounds like you just need to tighten the nut behind the wheel!
