I don't know the most, and I'm not the most understood on it either. It was suggested that a thread be started, so I'm doing it.
So I've read Smokey's patent doc for his hot vapor engine. I've also seen the idea shot down a lot because "you just can't have the mixture that hot" without causing det or auto ignition, or that it would melt the cylinder head, or any number of other reasons. I personally don't know the temperature that gas and air self ignites, or how much heat it would take to instantly melt a cylinder head. I also have not read of anyone actually building the thing and seeing what happens.
So let's discuss it.
Here is the doc that explains the system, or as much of it as Smokey wanted anyone to know.
https://www.dropbox.com/s/amgivqqevphb9jf/hotvapor.pdf?dl=0
So what do you think?
