made some stuff. Had to clearance bypass valve port a bit, to get touched up with a dremel next, Sent from my SM-G900V using Tapatalk
So I started drilling and tapping the charger body to attach the cover, you can also see I filled that gap with some steel epoxy, sanded smooth. I'm probably going to have 14 to 16 bolts holding the collector plate to the body of the charger, that is for structural purposes so I can use the plate for mounting. It will be going in front of the engine, with the outlet facing forward.
^ big intercooler
