1.8 swap
    You can use the steering knuckles off a 2001 - 2005 Kia Rio if you cant get the Aspire ones. I believe you also use the Aspire tie rod ends or Escort GT tie rod ends with the Rio knuckles. (Cheaper through Rockauto.com if you can wait until they arrive Via UPS).
    Jerry
    Team Lightning
    Owner of Team Lightning
    93 L Lightning. BP
      no adapter needed for the xr2 trans clutch cable. You may want to grab the xr2 cable though. You will want to move your engine and trans as far forward in the engine bay as you can when you make your mounts. this helps drastically with traction and stability.
