So I just picked up a 1990. Eventually a swap will take place, but I'm going to sort out the suspension, wheels and tires, and get a couple other projects done. On miata 1.6 motors common cheap and easy mods. Are to advance the timing 10*, diy intake, and swapping the air meter for one from a fc rx7. I was curious if timing advance was common on the 1.3? Does anyone swap to a miata 1.6 afm? I know if intake is messed with the exhaust side needs to be opened up also.
Cheap and easy efi 1.3 upgrades?
I know a certain someone who made more HP on a dyno with a Festy VAF on his Miata ( miniscule amount) so don't bother with the VAF. I think they both use the same code VAF anyway.
Advance the cam timing, advance the ignition a tad, ditch the cat, 2" exhaust and adjust the VAF on a dyno to make up for the added efficiency from the exhaust. Any other work will be a waste of time since your swapping the engine anyway. Some people swear that drilling the air box helps hp, but I haven't seen dyno results from this.
Your best bet is the just put the 16v engine in as soon as you can, even on the stock tranny.Last edited by Advancedynamix; 03-22-2015, 02:15 PM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
i seem to remember it said or was proven that the stock VAF could easily outflow the stock TB. i could go out and look but i'm thinking the stock VAF on my 1.8 escort has the same openings as the festiva VAF and will still outflow the 1.8 TB. even the miata forums discourage the taller RX7 VAF for all but the most radical builds.
drill the VAF regardless. the added growl at least makes you think its got more power.
Fixed it.Originally posted by F3BZ View Postdrill the airbox regardless. the added growl at least makes you think its got more power.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
"I think they both use the same code VAF anyway"
I can not find a difference between them, on the bench or dyno, except where the base setting is, 1.3 vs 1.6 Miata code "S" Festiva code "T"
"i seem to remember it said or was proven that the stock VAF could easily outflow the stock TB. i could go out and look but i'm thinking the stock VAF on my 1.8 escort has the same openings as the festiva VAF and will still outflow the 1.8 TB. even the miata forums discourage the taller RX7 VAF for all but the most radical builds. "
Yup.No car too fast !
Regular preventive maintenance is probably the single thing you can do as a car owner to keep your ride happy and save money on repairs in the future. However, not everyone agrees on what preventive maintenance is, what you should do, and when you should do it. Let's clear that up, and give you some tips that'll apply to any vehicle.
PREVENTATIVE VEHICLE MAINTENANCE
Originally posted by Advancedynamix View PostI know a certain someone who made more HP on a dyno with a Festy VAF on his Miata ( miniscule amount) so don't bother with the VAF. I think they both use the same code VAF anyway.
Your best bet is the just put the 16v engine in as soon as you can, even on the stock tranny.That's really interesting. One of the reasons I was thinking of going to MS on my Festy was to get rid of the VAF, for better intake airflow. I had assumed that the small opening in the VAF was a big restrictor to the system; but apparently not?Originally posted by F3BZ View Posti seem to remember it said or was proven that the stock VAF could easily outflow the stock TB. i could go out and look but i'm thinking the stock VAF on my 1.8 escort has the same openings as the festiva VAF and will still outflow the 1.8 TB. even the miata forums discourage the taller RX7 VAF for all but the most radical builds.
As far as drilling the holes, it made a giant difference in my 1990 Subaru Loyale, which had an airbox intake no larger than the Festy's, even tho it was a 1.8L motor! Above 3500 it really woke up after the airbox mod. Maybe not so much for Festys, but there may be some benefit; plus it's free and sounds cooler.
How do you adjust the VAF?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Pop the black cover off and there is a spring tension adjustment. There is also a bypass screw iirc. It's under the aluminum plug.Originally posted by TominMO View PostThat's really interesting. One of the reasons I was thinking of going to MS on my Festy was to get rid of the VAF, for better intake airflow. I had assumed that the small opening in the VAF was a big restrictor to the system; but apparently not?
How do you adjust the VAF?Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Charlie! You said too much or not enough!Originally posted by Advancedynamix View PostPop the black cover off and there is a spring tension adjustment. There is also a bypass screw iirc. It's under the aluminum plug.
Ok, for those who must, DON'T do this with out a dyno or fast wide band!
To get the cover off with out destroying everything, first use a hook pick or other small tool to carefully remove the silicone seallant around the edge of the cover, be careful as the cover is under the sealant as well and is very thin/fragile. Remove one screw holding in the electricle connector, don't lose it! Then put on safety glasses and gloves, holding a rag over the cover with your gloved hand, blow compressed air with a rubber tip blow nozzle in small dosses, just "bumping" the valve untill one edge comes loose, then hold that edge down and blow some more and thr cover will come loose.
At this point, MARK the face of the toothed adjuster wheel where the spring lock engages a tooth.
If you are careful with this delicate instrument, you can ease back the lock and move the toothed wheel. clockwise is leanerNo car too fast !
Huh? That's not what this thread is about.Originally posted by jhonmax12 View PostRegular preventive maintenance is probably the single thing you can do as a car owner to keep your ride happy and save money on repairs in the future. However, not everyone agrees on what preventive maintenance is, what you should do, and when you should do it. Let's clear that up, and give you some tips that'll apply to any vehicle.
PREVENTATIVE VEHICLE MAINTENANCE90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
