Looking to start piecing together a rear-turbo setup for my 1st gen B6.
First off, I would like to know what would be a good easy to find turbo, and what cars to find them off of?
Second, what would be the best, cost effective lines to use for the oil lines.
Third, would PVC piping from a hardware store be any good to use?
Fourth, How do I use the FMU to keep it from leaning out at 8PSI?
Fifth, Is there any difference between an Adjustable FPR, and a FMU?
Sixth, Do I need an upgraded fuel-pump for 8PSI of boost?
Seventh, Will a B6T oil pan fit a B6 SOHC? This is just to avoid having to tapping my own drain in the stock oil pan. Or any oil pan off another engine that has a turbo drain.
Eighth, What t-fitting do I need that will fit in the oil pressure switch hole, so I can run an aftermarket oil pressure gauge and the oil feed line?
I will ask more questions when I can think of them. lol
