So i was reading these:
And it got me thinking.
How would you estimate the hp on a build like this.
Running an NA b6d (for a base so we are all on the same page) at a compression ratio of 13:1 or greater on e85.
And what about splitting the duty of raising the compression ratio between the head and the pistons say a 75% increase by pistons and 25% by head work?
I also read that the cam would possibly have to be changed out to compensate as well, so i need to learn about cam profiles.
So by all that I have read, theoretically, this should produce an ingine that is good on low end tq, less chance of detonation, increased chance of pre ignition. But, it should have a good streetable feel to it.
Since it will be taking away from top end, which ill probably never see, a turbo could be used to compensate for that.
So am I pretty solid in my theory?
What have I missed or gotten wrong?
Help me out!!
Help me out!!
