Im looking at a car right now with 162k. My understanding is the 1.6 Dohc engine is somewhat desireable, and I could swap a 1.8bp into it somewhat easier than the V6 model?
I was going to pick it up last night but the car had no spark. He had jumped it due to a dead battery from sitting and claimed it started for 10 seconds then died. We checked the fuses and all the basics, then I went to check the ignition wires and found out the coil is IN the distributor!?
He said this happened once before and the distributor was the issue. Does anyone know how common of a failure this is and if there happens to be an easy way of using a different distributor with an external coil? The car is in good shape (too good to scrap!) and gets decent gas mileage. And long term I might swap the 107hp 1.6 into a festiva and use the 1.8 I have in this car...
Unfortunately I think the transmission is only a F-series, but they appear to be geared high at least.
