Hydraulic G Series Trans?
  • Hydraulic G Series Trans?
    Does anyone have any info on doing a Hydraulic g series swap? I have an Escort GT and was hoping to get by without sourcing a cable g series from a Capri XR2.
    Thanks.
    no more festy but im lookin
    87 AE86 GTS 13b swap
    92 Escort GT
    Im not sure specifically what you are looking for but when i did mine (donor was a protege) i had to drill a few holes in the firewall to mount the clutch master, plus i had to source a remote reservoir for the clutch because it doesn't have its own (on the protege the clutch master shares fluid with the brake master). I used a little brake reservoir from a sport bike. I also had to remove the clutch pedal and drill a hole in it so i could mount the clutch rod on the pedal.
    its a fairly straightforward deal but its in a difficult place to drill holes with the engine installed, plus everybody knows working in the footwell with the seat in place sucks too.
    "Its not fast, but its fast for a festiva."
      Okay, sounds super easy, just looks tight by the booster so I didn't know if anyone has tried it and found that it just wasn't worth it. Thanks.
      Sucks, I JUST bolted my dash back in like 45 minutes ago, haha.
      92 Escort GT
        You can do it with the dash in.
          One other option is to build a bracket for the cable and use it on the trans. There's several threads on here that shows brackets that were fabbed.
          Jerry
          Team Lightning
          Owner of Team Lightning
          93 L Lightning. BP
            Check my build thread there is pics on how to make a cable with a mustang clutch cable and pics of plate.
              I found you can just take the resevior and remove it from the protege and swap it on to the festiva master easily.
              - Form should follow function...
                Excellent, thanks for all the info. I'll definitely check out your build thread, Hot_wheels.
                92 Escort GT
