Found this turbo on ebay, Looks like it would bolt up to the factory exhaust manifold of the B3. I have attached a picture of the measurements. Does anyone have measurements of the factory flange or the gasket?
Turbo with factory manifold?
I was about 5 minutes away from buying enough material to build an awesome b3 turbo manifold this morning. Are you interested at all? I have one aspire flange in my possession that's begging to get welded to.
idk i'm trying to see if this turbo would fit if so it would save me a lot of time and moneyOriginally posted by bhearts View PostI was about 5 minutes away from buying enough material to build an awesome b3 turbo manifold this morning. Are you interested at all? I have one aspire flange in my possession that's begging to get welded to.
44mm, that's schedule 10 1.25 inch pipe I.d.Originally posted by TurboAspire View PostFound this turbo on ebay, Looks like it would bolt up to the factory exhaust manifold of the B3. I have attached a picture of the measurements. Does anyone have measurements of the factory flange or the gasket?
Indeed. It was actually a double-flip sort of. Because I had a "gonzo pipe" that 180'd back down into the turbo. The turbo would stick WAY out of the hood if you just flipped the manifold and put it on there.Originally posted by bhearts View PostBut he chopped the runners off and welded them back on upside down.
