aspire fuel tank into festiva
  • aspire fuel tank into festiva
    Hi guys
    i have a 3 door mazda 121 with a carby b3 in it ad im going to put an efi engine into it eventually and was wondering if an aspire efi fuel tank and pump would bolt straight in?
    cheers,
    Rob
    yep.
    it will bolt right in. i have one in my 121 easy peezy
    1988 MAZDA 121- B6T + G5MR SWAP IN PROGRESS.
      Good to know
        Do they have the same capacity?
          Yes. They're identical.
          Oh btw. It has to be a 3 door aspire
            Do you know if the 5 door sender and pump will bolt into a 3 door fuel tank?
            Cheers
              Not sure.
              One would assume yes, but you knew where assumptions get you
                Cheers
                Check if the parts cross-reference on an online sellers site. Like ebay or rockauto
                  I'm thinking there different 2 to 4 door that is . I put a 2 door sender on my festiva pump and it worked but the gauge was off when it hit E I had about a quarter left. I believe the gauges use different ohms
                  So even if it swaps in your gauge will be off.
                    The 5 door sender and pump will not work, it is different.
                    The Festiva Store
