Hi gang. So today's project is getting my tach and speedo to work. I have already figured out the speedo (broken cable) but I'm stuck on the tach.
My cluster looks to have been added later on judging by the yellow writing that says 88 festiva. In the back of the cluster there was a wire added to the terminal that says IGN. Now, I'm not sure if that was for the tach but I'm assuming it is. In the bay, that same wire was just hanging loosely. Now, I see a connector on the coil that looks like the wire came out of the crimp but it's on the negative pole. I'm going to try to connect my wire to that and see if that gets it to work but i was wondering if anyone had some info on where the tach signal for the cluster comes from. My manual says ignition but I don't have it handy at the moment. The car is an 89 carby btw. Thanks in advance.
