ive put a fuel injected 1.5 out of a 98 festiva into my 88 121 but the alternator isn't charging
The charge light on the dash stayed on, I tried a few different ways to hook it up and I think I blew the diode in the instrument cluster because it's not coming on at all now
so I rewired my own charge lamp/excitor with a spare T5 bulb I had.. Still not charging
So I figured it must be the voltage sense wire (maybe) it's a red wire that goes to the "head" main fuse.. Connected it to the battery and still not charging.
I've swapped the alternator and still same thing..
Any ideas? I'm getting 8.3v with the engine running
Cheers,
Rob
so I rewired my own charge lamp/excitor with a spare T5 bulb I had.. Still not chargingSo I figured it must be the voltage sense wire (maybe) it's a red wire that goes to the "head" main fuse.. Connected it to the battery and still not charging.
Cheers,
Rob
