BP SWAP in a 2000 Festiva/Aspire Trio - QUESTIONS???
  • BP SWAP in a 2000 Festiva/Aspire Trio - QUESTIONS???
    Hi Guys,
    I've recently bought a 2000 Festiva/Aspire for $200 and plan on swapping in a BP.
    I'm from Australia btw in case you were wondering why my festiva is a 2000 model, I'm pretty sure is exactly the same as the last Aspire that came out in the states though...
    Soon I'll be picking up a running 09/1994 Mazda Protege with the BP engine that I'll use as the donor vehicle.
    1) Does this vehicle have the G-series Tranny?
    2) If so, what axles will I need to work with the aspire hubs/struts?
    3) What problems am I likely to encounter?
    4) I think the Protege is hydro clutch, is it easy to swap in the protege pedal box/brake and clutch masters?
    5) Can I use the entire engine loom from the protege to keep wiring to a minimum?
    G'day M8! I've been surfing Wiki lately and found a lot of good ideas and info, here's a link that should tell you what trans you've got there...
    The FS DE (T) engine in the '03 protégé looks interesting
    Most people don't drive what they want at all, and never will
