g series questions
  • Festiver
    replied
    Originally posted by Advancedynamix View Post
    If you want your axles to be centered properly and your engine to sit nice and parallel in the engine bay, you'll need to clearance the drivers frame rail when you install a G series transmission. Where, all depends on your mounts. In this picture, you can see where I pounded the frame in about a half inch with a torch and a sledge hammer. There are several layers of steel in the frame, which makes it really hard to pound in.
    Thank you so much haha the missing link of info
    Sent from my XT1585 using Tapatalk
  • Advancedynamix
    replied
  • Festiver
    replied
    Originally posted by bhearts View Post
    No idea. Hopefully something else chimes in
    Hopefully
  • bhearts
    replied
    Originally posted by Festiver View Post
    Yeah I was expecting to do the driver rail but i gotta research more huh? Haha
  • Festiver
    replied
    But if you can't get a bp/g to fit in your frame rails then you can mark it for cutting
  • bhearts
    replied
    Yeah yeah I do actually I'f I move forward I have more pully clearance
  • Festiver
    replied
    Aren't you wanting to g swap? And move the engine forward
  • bhearts
    replied
  • Festiver
    replied
  • Festiver
    replied
    I see the issue. You can't test fit to mark for clearances if you can't get the engine to fit
    ? The engine fits it's mounted I'm easily confused sorry
  • bhearts
    replied
    Right now it's bp E swapped and the alternator is super close but not touching do you think the trans location changes left to right? Thatd be a shame engine looks so good where it is
  • Festiver
    replied
    I think is precisely why you'd want to test fit it first.
  • bhearts
    replied
    Idk honestly I know if you use the bp crank pulley vs. the b3 you have to notch the passenger side
  • Festiver
    replied
    Isn't it usually the passenger side that gets notched on that configuration?
  • bhearts
    replied
    I'm doing a bp g swap
