I'm making my own 4-2-1 unequal length header for my turbo b6d project. Nobody sells simple prefabd 1.25 sch 10 304l stainless 2-1 merge collectors. So I'm stuck making my own. I went out and bought a double angle miter saw hoping I could just whip out reliable and reproducible merges. My first jig caused alot of blade wander because I was starting the cut on the side of the pipe. This technique was never going to work with double angle cut pipes if i wanted to make 4-1 collectors. It was not accurate enough.
And then it hit me. This was how to do it
My mdf wood clamp holds very firm, and I only have clean up towards the bottom of the cut due to depth cutting issues
That was with the pipes merge start point lined up. Pipes turned out a touch different length but I think it will work fine, just need to trim up the outlet after welding.
