whats the base timing on a stock b3 and whats the best timing for performance on a stock b3?
STOCK B3 timing
10 degrees btdc-stock. for a little more performance add 2 or 3 more degrees. if your engine starts pinging on the gas you use back off the timing till it stops doing that. mine runs fine on the cheapest regular i can find at 12 degrees. remember you have to bypass the computer to check/set timing. do a search the info has been posted before.91 u.s. festiva L 189423 mi. GL int. , engine started smoking [sold]
93 u.s. festiva gl 222000 mi. bad engine , parts car [sold]
1981 ford F-100 400000+ miles ? , looks rough - runs good
1963 1/2 Ford Falcon 4 door base model , 106000 original miles , second owners
