I have a line on a 91 323 but am slightly confused on possible swap. Can the engine from a late (91) 323 be swapped the same as a first gen? Does the intake from said engine work or will I have to use the Festys?
2nd Gen 323 engine?
Festiva intake will bolt to a 2nd get but the coolent ports won't line up.
I ran a 2nd gen b6 with a carbed intake and plugged off coolent ports I was racing this engine so I didn't worry about it.
The 2nd get b6 can be swapped right in. As the 1st gen you will need the ecu and afm as well. I believe it's a b61k ecu code Thats also what you use on the 1 gen iirc.
