Msd install
  • Msd install
    looking to install the MSD 6al2 ignition box on my festiva with a BPT but cant figure out how to wire it up? anybody got expirence with this? And where is the signal from the distributor sent to? tried some of the instructions msd shows but car will only crank and not start, tested msd box and it works, coil is good, runs fine with stock ignition hooked up, thanks also i have a stratified ecu thats for a ford escort application,could this be causing problems?
    Probably better off with megasquirt
      I just installed a full MSD setup on my Festiva, do you still need help?
