Okay so I found a 2004 sephia 5 speed. It was rear ended, and it's 150 bucks so I'd like to know if the engine and trans is swappable into the festiva. He says it's a 1.8. BP? And any info on the hydro to cable conversion is also appreciated. Thank you all in advance!!
Help!! Sephia engine and trans?
read up on here the bp never came in the 04 sephia only the 95-97 RS, LS, and GS. the 04 does have a 1.8l engine but it is a T8D which is a kia made motor and will not work in a festiva without heavy modification i made the same mistake with my first festiva
after you look on there to see which cars used the BP go on here to see if anyone near you has one
this is the motor it has in it
this it what it look like in a festiva altho not recommended to go this route, this project was never finished due to rust but you would have to use custom made axles which are expensive and a pain all around so best just to find a bp
						Last edited by monkeykiller1996; 06-11-2017, 10:07 PM.88 L carb'ed (when up in flames of glory)(deceased) 4spd
89 L carb'ed (died on the operating table (rust))(deceased) 5spd
93 gl FI (sold) automagical
89 lx FI megasquirted "luna" b6D+t (186hp 209ftlbs)
88 L carbFI megasquirted zombie car
You could use the transmission the g25mr but you'd need to find a BP or b6t and the 3 axles from a 91-94 xr2 or 88-89 323 gt
Sent from my XT1585 using TapatalkFestiver
93 L find/5 speed
BP/g15mr swapped
Aspire brake swapped
stripped and sold due to rust
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
But if you don't want to take that route I'd be interested in the transmission and related parts you're very close to me
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
A Rio shouldn't be too bad, as the chassis is similar to the Festiva/Aspire. But the Spectra is a completely different animal chassis wise... much more work involved over the Rio option.Trees aren't kind to me...
Too bad the Rio only came with a 1.6L engine. I guess that I'll keep looking for a '95-'97 Sephia if I want to do a swap into a Festiva.
I had an '04 KIA Spectra years ago, and the motor and trans were pretty nice, even while the rest of the car was kind of a turd. It wasn't really sporty in any way, but that motor would've had plenty of power for a Festiva.
Have you looked at Mercury Capris as well? Easy way to get a B6D. Are you in Denver CO? It shouldn't be too hard to find a donor nearby.Originally posted by discontinuuity View PostToo bad the Rio only came with a 1.6L engine. I guess that I'll keep looking for a '95-'97 Sephia if I want to do a swap into a Festiva.
I had an '04 KIA Spectra years ago, and the motor and trans were pretty nice, even while the rest of the car was kind of a turd. It wasn't really sporty in any way, but that motor would've had plenty of power for a Festiva.Will Samet
How to find me:
Feel free to PM me anytime!
Instagram/Twitter: @WILLSAMET
