Hey guys I have a 93 festiva just swapped in a b6t from a 93 mercury Capri xr2 with only 80,000 miles. The motor definitely has more power then the b3 but nowhere close to what it should. It take almost 5 full seconds to build boost to shift to next gear. Compression is good no leaks looking for some advice. not so noticeable Blown Head? gasket
B6t swapped festiva, not the expected power
Unless you left a blanking cap or rag in an intake component, or have a serious rats nest in the exhaust, (had both, some of us are slow learners) recheck ignition timing, if correct (13/14 degrees BTDC), recheck cam timing, report findings.
While we are mulling over your findings, check the correctness of every vacuum hose, security, free flowing, routed to the correct nipple of the correct component.
assuming no check engine light, blah blah blah...Last edited by Dragonhealer; 06-21-2017, 10:52 PM.No car too fast !
Post a picture of the engine from above. I have seen 2 people criss cross the vacuum lines that go to the throttle body and kill performance."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
Way back in the day when I did my first b6t swap I found one of the injectors had a loose wire. The car was running on 3 cyls but because it was still at least as quick as the Capri the engine came from I didn't think much of it until someone pointed out the constant miss fire. It sounded lopey like a Subaru.91GL BP/F3A with boost
So adjusted timing to 13 degrees btdc made a hug difference. As far as vacuum I have left it like I got it. Vehicle is still getting warm. I'm running a factory festiva radiator with a 1770cm fan.attaching photosIMG_20170622_095156.jpg
