Intake for Carbed Engine
  • Intake for Carbed Engine
    Is anyone running an intake on a carbed b3 or b6 that is other than stock?
    If so, what is it and do you have any pics? I'd like to put something else on there if for no other reason than looks.
    Thanks!
    In the beginning the Universe was created.
    This has made a lot of people very angry
    and has been widely regarded as a bad move.
    -Douglas Adams
    [1989 B3 Ford Festiva L]
    I just bought an 88 manifold off of eBay. It is slightly different than the 89 manifold. It appears that the heat spacer was not there since it is lower and has all the vaccuum ports close to the base of the carb.
    I also bought a dual Hitachi carb setup from Australia off of eBay. The runners do not line up at all, however the carb linkage will accept the stock cable pull. I will be attempting to make a one off cheapo manifold using the lost foam technique. I bought some nichrome wire off of eBay to cut the foam. I also bought a foam knife at auction. I should call my Festiva "ten cents on the dollar".
