Injectors
  • Injectors
    Found an old miata at the yard. Will they fit in my 91 for a little more power?
    Sent from my LM-X210(G) using Tapatalk
    No they're bigger and more fuel is pointless without more air.
    Sent from my SCH-I545 using Tapatalk
    Better Than Nothing Racing
    Way too many cars
    :woc:
      Im doing a supercharger setup
        If you are using the stock ECU, stick with the stock injectors. Stock system will support 4psi boost no problem.
        No car too fast !
          Can u help me through the process? Looking at an amr 300 charger
            I have no experience with that particular blower, but it may be suitable for a low boost B3.
            I hate to commit right now as we are frantically re-upping the BP powered land speed '27 Ford roadster modified for this season. I'll help as I can. There are plenty of others here who are quite knowledgeable and can chip in as well!
            Having looked at pictures of the unit, perhaps it could mount on an AC compressor bracket?
            If you are not familiar with blower setups, check out some on line tutorials for theory and fitments.
            No car too fast !
