I  question  your  C/R  math, sir.    At  34cc it  would  be 9.7:1,  but  you  need  to add  head gasket  thickness, valve  reliefs, piston  below deck  height  and  area around  the  piston  top down  to  the  first  ring.  Figure 2 - 3 cc, call it 2.5.  That  would  be  1324 divided by 4 = 331,  331 divided  by 36.5 = 9.1:1  C/R.   I  think  I  will  mill  the  head  0.035"  to 0.040"  to  get  somewhere around 10:1  C/R.
SOHC 16V Head swap?
And you are right to question. Math assumed a flat piston at deck hight. CR=(swept volume+static volume) / static volumeOriginally posted by hot4dl8ly View PostI question your C/R math, sir. At 34cc it would be 9.7:1, but you need to add head gasket thickness, valve reliefs, piston below deck height and area around the piston top down to the first ring. Figure 2 - 3 cc, call it 2.5. That would be 1324 divided by 4 = 331, 331 divided by 36.5 = 9.1:1 C/R. I think I will mill the head 0.035" to 0.040" to get somewhere around 10:1 C/R.
(331+36.5)/36.5
I think you will need to cut valve reliefs in the pistons if you cut the head.No car too fast !
I really must apologize. I wasn't adding the combustion chamber volume into the amount being compressed - I had to look it up and that is exactly correct. It is part of the amount being compressed, even if it is the amount being compressed into. I might have wound up with a 11:1 premium only engine. I thought the factory was fudging the C/R #'s all these years. Thank you for setting me straight, M186,000 miles per second is not just a good idea, it's the law
1990 yellow L+ (l8ly)
1990 yellow L+ (sunryz)
1992 aqua L (agua)
1993 blue L (aurora)
