Just wondering would anybody happen to know what the weight of a dohc bp, dohc b6, and stock b3 longblocks weight ? I have tried searching this site and the web with no luck so any help would be appreciated. If possible just the weight of the long block itself no accessories intake or exhaust manifolds just valve cover to oil pan. Thanks
Engine Weight
~Jeff
2003 Mustang GT 5speed
thanks I thought I remembered seeing something on here before but I couldnt find it with the search. I still need more weights but that is a start. I guess the biggie now would be the longblock weight of a bp dohc. maybe I ll try the miata forums or something.
The B6 short block should be lighter than the B3 short block since the piston holes are bigger.
However, you need to take into consideration the FI and other bolt ons up top. For example, the older B6s have essentially the same FI routing, plenum style etc., so they should be about the same weight as their B3 counterparts. The newer B6s may have heavier (or lighter, for all I know) FI systems and plenums.
There may also be a weight difference between exhaust manifolds, too. Probably only a pound or two, but that may be the block weight difference as well.
