are their any throttle bodies and intake manifolds that will bolt to the aspires
throttle body swap
depends on the year of the aspire....i don't know if ob2 had anything to do with the throttle body. But the one from the escort/protege should bolt up.---------------------------------------------------
I'm not sure if this will help, but when i had the new plenum made, we moved the throttle opening to the side. While we were at it, we bored the throttle opening from 68mm, to 70mm and had it polished. I would have thought that a small increase in throttle response and power could be acheived- though it really was part of a bigger picture....
Poverty produces creativity
