I have a question. My engine is still running really rough and I am running out of ideas as to the cause. It idles smoothly, but the plugs are soot covered and there is very little power available. Step on the gas and it just hesitates like crazy.
Something I realised though. I am using the capri injectors with the festiva ECU. If the capri injectors are bigger than the festiva injectors, then wouldn't the base fuel maps be wrong, and the car would run very rich?
After maybe 10 minutes of driving I got a CEL code 17, O2 sensor failure. Could this be because the mixture is so rich it just assumes the o2 sensor is faulty?
