What do I put in the places where the CV axel goes to keep the spider gears from moving and me having to tear the trans apart to place them back? Is there a special piece that I can get at the parts stores or what? This is my first time removing a transmission with the intent of putting it back in.
GM25R removal question, well, it's really for all FF trans.
Tags: None
I have had my tranny removed twice and I moved it around the garage both times,I never left the axle's or anything on..Everything was in its place!!!
I've used a couple of pieces of heater hose that I had lying around before. A chunk of dowel the proper size will also work. Nothing special is needed, just something around the size of the axle to keep things in place. Good luck.1991 L 408,000 miles+ w/NEW B3 longblock!!
2008 Nissan Versa S HB
I've also never had a problem with my transmission in the 4-5 times I've had it out of the car.
If you want something in there, get an old axle and cut it so you have a couple inches sticking out of the tranny. Attach a nice loop on there so you can grip it.OX SMASH!!
zip ties will work too, metal wire, ext....Ian Carr
88' flat black festy, has an e-brake that works!
99' S70 T5M- faster DD
86' 951- almost ready for track season
My old b6t- wish i still had it
http://www.cardomain.com/ride/2241793
Every car I have owned has had a turbo in it, until I bought this latest festiva.. I plan to fix that though.
That's what I use, too. I take the cir clip off the end so I don't have to fight to get it in and out. You only need to put something in one side to stop the spiders from rotating out. And yes, I've had 2 transmissions that I had to take apart to put the spiders back in position. One, I have no idea how they fell out but the other I do know. I had both axles pulled, the transmission was in gear, and I was using the starter to spin the engine to check the compression.Originally posted by xpnsydI use the old green c/v ends.You gonna race that thing?
Thanks I'll just stuff some kittens in there. Or whatever else is laying around.
I had them rotate on the GTX's BPT trans. I was lucky and got them to roll back into position but on the fwd trans they can drop. Use an old axle, zip tie, wire, broom stick.....
Old broomstick ends for me. Held in place with duct tape.
I can't pull my G25MR out of my Festiva without pulling the engine bolted to it, so while the transmission is being moved around, it still has the intermediate shaft holding the gears in place.
Oh yeah, I have a Phantom Grip too... which should hold the gears in place as well!* Retired Festiva-er*
1990 Festiva - The Once Fastest Red 1990 Festiva LX on this site! - now in more dedicated hands!
B6T'ing since May 2002...
Disclaimer: I'm a dick, deal with it.
Poverty produces creativity
