What mph does 4th gear end?  I just need a ballpark figure.  Let me know what you know along with the size of tires that were used.
XR2 capri B6T tranny?
	Tags: None
110 mph, thats what the dyno read when I dynoed Mextiva with 175/60/13 tires...
Originally posted by MEXTIVA110 mph, thats what the dyno read when I dynoed Mextiva with 175/60/13 tires...
That can't be right. 3rd gear goes just to 100.
I dynoed the car when it first came out of the shop so I could be wrong..Then again when you shift from 3rd to 4th your rpms dont drop as much and I dont think 3rd will do 100mph.
gimme like 40 minutes till im back in my room i have the website and ##'s you need to find out your speed. I believe it is up in the 115 range, 3rd gear ends at about 91ish if i recall... gimme a couple minutes
-IanIan Carr
88' flat black festy, has an e-brake that works!
99' S70 T5M- faster DD
86' 951- almost ready for track season
My old b6t- wish i still had it
http://www.cardomain.com/ride/2241793
Every car I have owned has had a turbo in it, until I bought this latest festiva.. I plan to fix that though.
Assuming 7000 RPM and 185/60-14 tires.
With a 3.736:1 final final drive (is this right?) x 4th gear of 1.028:1, I get 121.5 MPH
For the drag strip, I like the EGT ratios.
4.105:1 and 1.028:1 gives 110.2 MPH @ 7000 RPMFestiva: Because even my dog can build a Honda.
I got those ratios from https://www.vibratesoftware.com/html...sions_Main.htm. I also read it wrong. According to them, the Capri has a 0.97:1 4th gear
this would give a top speed in 4th of 128.8 MPHFestiva: Because even my dog can build a Honda.
Ian, Appears to be right there with me, It was 110 to 115 mph....
I saw you dyno shee over @ the turbo forum, Next time you dyno your car make sure and take notes....I know I will when I dyno mine!!!
Poverty produces creativity
