I want to swap a aspire 5 speed for my auto since the aspire has a better 406 final drive.  Are there any differences between the two transmissions that could cause any hang ups in the swap process?  I assume  that both are identical except for the final drive gear.  Should I use the aspire speedo cable instead of the festys?
Festy vs Aspire
on the other side of it i'm installing a festy trans into my aspire whats the differences in the gearsWait what kinda car is that!!! Oh yeah thats a ASPIRE
http://www.cardomain.com/ride/801871
Well 1st through 5th gear ratios are the same however the final drive ratios differ. The Festiva has a 3.777 and the Aspire has a 4.06 which means the aspire will accelerate faster but have a higher crusing RPM. You can use a gear speed calculator to see the actual difference in MPH at the shifting RPM and the cruising RPM differences.You got the stickers I got the parts!
