What is the difference between the auto and manual festiva axles?  I have an auto and I am swapping in a manual do I need to change axles or hubs over the manual ones?  Is it the length or splines ( if splines is it the ones going into the trans or into the hubs?).  When doing the aspire swap do the hubs differ from manual to auto.  Thats about it before I start pulling the car apart.
axles
The auto ones are fatter on the end that goes into the trans. The hub end on the auto and manual shafts are the same as well as the same between the festiva and the aspire.
Also, the Aspire axles (like the Aspire control arms) are a bit longer and won't work on the Festiva. Just in case you were wondering...
