i know a honda has the same thread pitch, you could use one from a civic application. I use honda oil filters on my car, manufacturer HAMP. Better than K&n imo
The summit kits are okay, buy different lines or they'll start to leak pretty soon.
AMSOIL has a very nice kit....if you have the money.
AMSOIL also has a bypass filter kit. A bypass filter will filter to below 1 micron. Wear causing particles are >5 microns. A good full flow oil filter is usually in the 20 to 25 micron range. Of course, you're looking at about $270.
