Sloppy Shifter
  • Sloppy Shifter
    Festiva has a short shifter installed (Pacesetter), the throw is fine... But I can move the shifter about 2-3" from side to side while it's in gear.
    Any suggestions on where to check? Loose bolt maybe? Or do I need the new bushings I've seen floating around?
    Simon - pimptiva.com
    Geneva dirt just fixed this in his car. either PM him or do a search on him for it.
    93 GL modyfied!!!
    :fish:
      I used bushings from hinges for like a van door. They are in the help section at Autozone. I have also seen them at Napa.
        Sounds like the bushings on the stabilizer bar are bad. I grabbed some off a '96 Aspire and everything was fine afterward.
        White '89L auto - Sold!
        Silver '06 Rav4, 95k!
          From looking at the rest of the car, my guess is that it was a ghetto install on the short shifter too... I'll check out those bushings and hopefully it fixed the problem.
            my stock shifter is pretty sloppy too. is there any way to clean up the stock shift feel?
              same method should do it.
                thanks man
