how hard would it be to put a body kit from a different car on a 89l would be. i was thinking a crx on mine maybe
crx body kit
Well it all depends on your fabrication skills. I measures a Honda Civic the older boxy style before they turned bubbly. It was about 1 inch wider than the festiva front and back. So you would have to cut 1 inch out of the middle of the bumper, and fiberglass, or resin them back together, use some flexible bondo over that, sand it all down, and paint it. THen drill new mounting holes in it to match the festiva's. That is an ideal situation :-)
i had looked into this as well, to me the 88-91 civics are the best to get a body kit from
sounds kinda ez but i could be wrong i might try and find a crappy messed up 1 and try it first if it turns out i did i good jop ill get one and put it on thanks for the helpOriginally posted by Gforcefdyou would have to cut 1 inch out of the middle of the bumper, and fiberglass, or resin them back together, use some flexible bondo over that, sand it all down, and paint it. THen drill new mounting holes in it to match the festiva's. That is an ideal situation :-)i love my lil red wagon
