I have some questions about rust repair on my '91 festiva L-plus. There was a good bit of rust along the bottom of the sides, especially right in front of the rear wheel wells, which i took a grinder to and cut out, planning to fix it with fiberglass, but there's some rust starting on the inside that im not sure how to get at. If i were to miss some, could I use some rust stopper , or will I end up with rust eating from the inside out? I have some pics:
-driver's side in front of the wheel, light rust all over, and some inside the hole of the important looking structural stuff:
Also, up front on the driver's side, by the way, was I supposed to destroy the strip at the bottom?, :roll: :
And finally, the passenger's side. not too bad outside:
But inside is some ugly lookin' stuff breaking through:
Anyone with some experience in this area know where the water's getting in and how to keep it out?, i've seen a lot of rust in this exact same spot on festivas around York, Pa.
