FLAMES!!!
  • FLAMES!!!
    ok...here is a trick my uncle tought me.
    i put a sunroof in my 90 festy (never had one so i had to cut it out) thus cutting my headliner. i cut the hole in the head liner a little too big so i had to go back and paper mashay (cant spell it) around the sunroof and trim it all up to fit snug. now for the cosmetic part. i took my headliner down and debated for a while about what to do to make it look better. i got ahold of some 3/4" soft foam polly from my uncle (have no clue where you can get it if you want to do this) i laid it out on my headliner and drew flames on it (just regular "hot rod" flames) i then cut the flames out of the foam....all one piece by the way. i stripped my old headliner lineing off. i bought a cheep can of spray glue and sprayed my headliner where the flames were going and placed the flames on the headliner. (**NOTE below**) then i sprayed the entire headliner and foam flames and covered it with a dark blue felt. the finished product......i have 3D flames in my headliner that look realy sweet!!!!!!
    NOTE: to make the flames flow better with the headliner....after you have your flames cut out...take a SHARP razorblade and make a 45* cut around the entire edges of the flames to kinda round things off a bit
    if you want to do this to your headliner and dont understand what i wrote ^ there...email me and il try to do better
    you dont have to do flames by the way. my uncle did a verry intricate ford logo in his 58 ford pickup
    sorry so long
    90 L FI..second B3
    90 L Parts car
    Jay
    Got any pictures you could post?
    Kevin
    '93 L (BP{T} Sold
    '90 L Plus Sold
    '94 Mercury Capri XR2 sold
      Yes, please post any pictures of it.
      1988 Mazda 121DA canvas top
      -73hp B3 multiport EFI swap
      -KYB SS w/ Eibach -35mm / FMS HD rubber suspension parts
        Hope the cheap spray glue you used wasn't to cheap because in the hot sun it may fall down. :lol:
        Thanks :wink:
          the "cheap" can of spray glue was just that...cheap. didnt take any of that into consideration when i did it so after a little over a month its falling down. oh well...im goin to get some industrial spray glue from my work somtime this week and redo it. sorry i dont have any pics but il look for some online, or snap a pic of my uncles if i see him first.
          90 L FI..second B3
          90 L Parts car
          Jay
