Ok, you need a flathead screwdriver.. on the back end if the window crank using the flat screwdriver kind of move the plastic escussion ring and you will see a brass looking horseshoe clip. get up under the middle of it and pry it out be carefull they're "springy" for the lack of a better word. I just lost 1 tonight. Went to pry it off to put in my new 90LX Power mirrors and it shot past my head never to be found again (at least not tonight) I'm glad I have spares..
To put them back on, snap the horseshoe clip back on the handle and push it on until it clicks...
Jesus is on my dashboard, But the Devil is under my hood
1988 ford festiva...in limbo, apartments suck
1995 Ford Aspire...in limbo, wow i need a garage
2002 vw jetta wagon 2.0L, neuspeed p-flow 1994 Mercury cougar xr-7 v8, lowered, 18's
I like the rag trick better too, normally the clip will catch on the rag and not spring so damn far. (the rag trick is taking a thin rag and sliding it behind the crank. Turn the rag until you catch the pin and pull (IIRC - The clip faces the handle on the crank, so slip the rag down as if you are going away from the crank and it should pull the clip out.)
You can pickup replacements at most autoparts stores incase you do lose one.
you think the rag trick sounds bad just wait till i explain the kotex trick for removing stripped bolts...
well ya know i'm workin on gettin rid of it right after i get rid of her body roll.
ohhh shit that was a wicked flash back LOL never have fun with a women you have never had fun with for the first time in ur car in the middle of winter..... only occurance i have ever had... couldn't get away with the windows down till she was out of the car.... then i hung my head out the window and went like 80 in 0 deg weather LOL so much for that first and last date LOL
