I've always hated those braces in the back of the car when the interior is removed... So today I finally did something about them. I had started doing this sometime before parking the car last year and never finished because it was a big pain...
I took a punch and staked a small hole in each of the spot welds and then drilled them out with a 1/2" drill (thanks for the suggestion FB71).
It took almost 35 minutes per side to get through the things... There must've been 20 spot welds per side.
I got through all of them and only hit the outside of the car once. That'll be an easy fix though, and the back looks a lot cleaner than it did before.
Tomorrow I fix up the hole I made, clean up a little and spray paint to keep from rusting. I also picked up a few extra cans of paint so maybe I can give the bodykit a quick cover.
Pics tomorrow probably.
