Rubber Inserts in the Spare Tire Storage Area
  • Rubber Inserts in the Spare Tire Storage Area
    What is the purpose for the 3 Rubber Inserts and holes in the spare tire area? Mine are leaking and rust is forming and I thought about sealing up the holes with bondo and spraying the whole cargo area with truck bedliner to stop the rust.
    If the holes have a specific purpose, I will leave them alone and try to find another rubber insert.
    1991 Ford Festiva
    The BEST CAR I have EVER owned!!!
    With the current gas prices, EVERYONE wants a FESTIVA!!!
    They are there to drain out any liquid that may end up in the tire well. It is a nice place to sweep all the little debris that collect in there too. At least that is my take on it....someone may have a better answer.
      Draining leaks was my solution. When I got Casper home, the spare tire was filled with rust colored water. Popped out those plugs and made cleanup a LOT easier.
      I've noticed that the plugs cut down on a LOT of road/exhaust noise too when they are installed (at least, in my stripped Festiva anyways!)
      Simon - pimptiva.com
