My Screen Install
  • My Screen Install
    Well... The girlfriend and car team purchased me a 7" screen a number of years ago... It sat under my bed for the longest time, until I started working on it on Friday...
    I cut a spare trim piece from when I originally got the screen, but it's been sitting ever since.
    There was a case surrounding it, but it made everything too wide and fit in the space. I didn't feel like cutting my dash apart to fit this, so I just removed the case and stuck it in. I had a few ideas about how to mount it, but ended up with a couple L-brackets at the bottom to hold that in and then a zip tie up top to hold it in place. It's in there pretty good.
    I need to clean up the wiring behind the dash (there's just a bunch of excess I want to cut out) and then I need to get a new surround piece and re-cut it. I was rushing some of the pieces and ended up cracking the top. It'll hold me over for now so that it doesn't look too bad, but it needs touched up.
    At any rate. It works pretty good. Runs directly off my headunit, which plays DVD's and everything.
    -Simon
    Simon - pimptiva.com
    nice! I'd thought about doing that before too but I doubt I'll ever be able to afford a screen lol... good job though, it looks pretty slick :thumbright:
    No festiva for me ATM...
      Pretty sure the screen was less than $100 when they got it. Probably can be had for even cheaper now.
      It helps that I didn't have my HVAC controls in there anymore due to lack of a heater core.
        you should have a track layout of autocross on the screen
        http://www.cardomain.com/ride/2065064/1
        Paulbarrera12.com
        Festiva Visualizer Project
          Nice mod Simon !!!
          BPT, G5M-R, BP26 Exintake swap + Fidanza cam gear, NSRT4 FMIC + 2.5" piping, HKS SSQV BOV, Exedy clutch, 3" downpipe + 2" all the way back, Aspire brake swap, KYB GR-2 & FMS coil spring , FMS EURO body kit + Carbon fiber hood, Falcon RTX 15X6― + Toyo proxes T1R 195/45R15
            Haha... The only problem would be the tracks constantly change... I'm sure that if I had my laptop with me, I could probably do a quick layout, output to DVD format and then burn a DVD to play while I'm driving.
              That looks really good in there !!
              Nice job !!
              HD2500 Duramax Chevy
              Z28 LS1 power 500 +
                be sure to post a picture of it with the new trim piece finished.
                Nice mod, but I couldn't get rid of my heater for that. :lol: it just gets to cold here in the winter.
                  ^^just would need to take out the center ducts....there are other to take their place....lol
                    ^^yes but then I would have to remove the climate controls also for that setup. And then the heat would either always be on or always be off. :lol:
                      You could probably relocate the controls elsewhere... The most common place I've seen in "tuner cars" is in the glove box...
                        I did the same thing a couple of years ago,
                        but my screen went wrong...And I had to remove it.
                        Nice mod simon! , itīs really nice to have a screen in front of you in a festiva/pride , in my car i had a NES (bujajajaja) just for play something .
                        bye!
                          Looks good! Mine will play DVD's if I put them in the headunit, and displays the track lists for CD's that I play... It's good enough for me. At least it's finally installed.
                            It looks great clean up the dash trim and it will be flawless.
                            You could install the remote monitor sensors in your valve stems and monitor tire pressure while driving and get a monitor box and monitor your engine on the screen - kinda like in the Nissan Mirrano
                            I actually though about moving the HVAC unit since its cable driven doors you would just have to get longer cables and custom cut, my mode select door is actually this way already since it broke a while back.
                            92 GL - parts car
                            97 aspire - parts car
                            87 323 DX - daily driver
                              Nice!!!!!
                              Kevin
                              '93 L (BP{T} Sold
                              '90 L Plus Sold
                              '94 Mercury Capri XR2 sold
