I have been scrounging around and have found several good weight-related threads. This is my attempt to consolidate info from these threads into a single point of reference. If you have any info to add, please post it and I will edit the top post to include it.
My main sources:
First Draft:
(all weights are in US pounds. 1lb = 2.2kg)
Seatbelt Hdw:.................7.6
Window Regulator:.............3.0
Weatherstrip/trim:........... 4.0
Window frames:................7.0
Roof:........................76.0 - including partial windshield, headliner, pillars
Seat and frame:..............48.0 - Summit sport seat, with custom iron frame
Hatch:.......................43.0
glass:.......................25.0
hatch strut:................. 1.0
Door cards:...................6.0
dash:........................17.0
Heater box:...................8.0
Sound deadening:..............6.0
Heater tubing:................2.0
radio and trim:...............4.0
speedo:.......................2.0
Glove box:....................1.0
Hatch Seal:...................1.0
Rear bumper:.................33.0
Front bumper:................31.0
Head lights:..................8.5
Taillights:...................3.0
inner fenders:................2.0
Windshield washer:............2.0
Wiper motor:................. 2.5
Wiper arms:...................2.0
Wiring and misc:..............7.7
Rear jack w/securing bolt:... 4.03
Rear jack handle:.............0.73
Spare tire hold-down bolt:... 0.08
Spare tire:..................17.31
Trunk carpeting:..............2.08
Cargo Cover:..................4.73
Rear speakers (2 total):......1.50 each
Rear seatbelt reel (2 total):.2.23 each
Front floormat:...............2.63 each
Rear floormat:................0.94 each
Steel wheel:.................25.00*
Mag wheel:...................23.00*
Drivers-side trunk plastic
trim panel w/out taillight
cover:........................1.51
Passenger-side trunk plastic
cover:........................1.59
Rear trunk taillight bulb
access panels (2 total):......0.12
Lug Wrench & fabric
container:....................0.94
Fiberboard trunk floor/spare
tire cover:...................2.41
Hatcback panel trim
(on inside of
hatchlid):....................1.24
Plastic shrouding cover under
hatch trim:...................0.08
Rear wiper assembly w/wiper
arm & blade:..................2.77
Rear speaker grille trim
peices (2 total):.............0.77 each
Rear seatbelt anchor/clip
(2 total):....................0.37
Rear drivers-side
interior panel:...............2.38
Rear Passenger-side
interior panel:...............2.47
Rear seat w/pivot-
brackets & bolts:............28.90
Rear seatback anchor clips
2/3 bolts (2 total):..........0.19 each
Door sill trim peice
(2 total):....................0.46 each
Rubber door seam trim (wraps
around the sheet metal seams
inside of door, 2 total):.....1.20 each
*estimated/unconfirmed
My main sources:
First Draft:
Lug Wrench & fabric
Hatcback panel trim
(on inside of
Rear drivers-side
Rear Passenger-side
Rear seat w/pivot-
